How can I add the custom shading surface for daylight analysis (like Vertical fins)? If I add it as a honeybee surface, it is throwing error as it needs to be a closed brep. Which component will work well for this?
Thank you,
Vinu
Daylight analysis does not require closed breps. You should be able to use Honeybee_Surface. Please share a file if you can.
Hello @devang
i have attached the file and I have highlighted it in red.
archBldg_error.gh (923.7 KB)
Thank you,
Vinu
Daylight simulation works without any errors at my end.
This does not affect daylight studies
This doesn’t concern your daylight analysis. However, I would recommend you run an imagebased simulation to see if everything is being exported to radiance right
