I downloaded the ‘Shadow_range_study’ example script from Hydra. This script came with some example rhino geometry. When I run the honeybee/ radiance component, I am supposed to get an HDR image.
Unfortunately, when I run the script, I am getting an error '1. Solution exception: Failed to read the results!".
Check the version of Ladybug and Honeybee in that file. probably you need to update components (USE Honeybee_Update Honeybee components and Ladybug…). Because every version of LB+HB will work with the same version of components that currently installed on your system.
After the update, You need to reinsert new HB Run Daylight Simulation component and reconnect the component inputs.
Thanks for getting back. Unfortunately that did not fix the problem. I was already on honeybee latest version 0.0.61. But I did run the update and swapped the daylight simulation component.
However I have a copy of that same Shadow study example file from version 0.0.51 (this sample file is from before they uploaded samples to hydra). This file works fine and I am able to see the HDR image (although I don’t like the quality).
Any ideas why the old sample file works but not the new one? I have not made any change to either file, I just downloaded it and hit run.
Thanks for getting back to me on this. I did some testing on my side. This computer has the accelerad version of radiance. The honeybee script from version 0.0.51 works fine but the version 0.0.61 does not work. The ‘honeybee run daylight simulation’ component throws an error after running the simulation ‘failed to read the results’.
‘failed to read the results’. is a generic error message and is not really helpful to understand why is it happening. Thank you for sharing the GH files but I won’t be able to re-create the errors from the gh file. Can you share the “study folder” which is created by honeybee? There should be and error.log file inside the folder.
I opened the imageBasedSimulation folder. I saw 5 hdr files. I was able to open 4 of them (0,1,2,3) without any issues. The composite one does not open and I get an error (see the attached screen capture).
I think the problem is during compositing the four sub images into the whole image.
Is it possible to circumvent this split into four and re-compositing exercise? I like the old scheme where we did not have this. Can I change the script to do that? I don’t mind opening the folder and running the script from there.
