Should the surfaces have thickness in Rhino for analyses?
Hey Guys,
I have a question; should the surfaces have a thickness in Rhino for accurate analyses? (for both thermal and daylight) in other words, can I just extrude a curve with no thickness?
Thanks in advance!
For an energy model the thickness is defined in material description. The geometry should be a single face.
For daylighting the mode detail you add the more accurate the results will be.
You can create the room using mass-to-zone component and then add the details as HB-Surfaces. The zone will be connected only to the energy simulation component but you will connect both the zone and the HB-Surfaces to the Radiance simulation.
If you want to include the extra details as shadings in the energy model you should use the context component.
@mostapha thank you very much so there is no need to have a thickness in Rhino geometry (no extrusion for closed curves but rather extruding single curves or creating surfaces from points).
Thank you very very much.
