Simple glazing material/construction
I wonder if you offer the possibility to make simple constructions for windows with the 3 basic inputs (U-Value, SHGC, and Tvis) using the EnergyPlus class WindowMaterial:SimpleGlazingSystem.
Well, I found it myself. If somebody interested, it is called EPWindowMat.
Honeybee primer can also be helpful to find the components.
https://mostapharoudsari.gitbooks.io/honeybee-primer/content/text/components/EnergyPlus_Window_Material.html
