Hi
I am trying to work with some existing rhino geometry that are all rhino surfaces. I’m still in Rhino 5. Model units are set to meters.
I have a simple radiation ladybug “script” that I have used many times before.
See link here:
When I select a single surface to analyze (id eventually like to analyze all glass surfaces but started with one to test), the graphic output is really wacky, with a variety of color strands.
See link here:
Is it some issue with the geometry itself? I traced over with a new surface and set that to the brep and had similar results.
I never used to have issues like this.
Thanks!
-Scott
