Hi there,
Is there a way to simulate how much heat does a building volume radiate to the exterior public space based on exterior surfaces Surface Reflection Index? Id like to test and design parametrically a building form the optimizes this.
Thanks!
Maybe you mean solar radiation analysis?
Yes, I know there is that on ladybug. But it doesnt account for the material properties. Does it account for reflected radiation/light for example?
You should look at the HB radiation analysis option.
Look in hydra for examples.
