Simulation Error with Calculating Energy Loads
When I run energy simulation for monthly cooling and heating loads, I got the following message.
  1. The simulation has not run correctly because of this severe error:
** Severe ** DetermineShadowingCombinations: There are 23 surfaces which are casting surfaces and are non-convex.
What does this mean?
I have attached the building image in this post. Also input screen as well. I have assigned shading device to HBContext where as others to HBSurfaces.
it is a long corridor facing West, so I have installed lots of louvres along the facade to avoid excessive heating load throughout the year.
I can also upload the file if it is necessary.
Best
John
Hi John,
Please check this and this. Hope that helps.
-Devang
thank you! I will have a look to investigate my file.
If I cannot resolve the problem by myself, I will kindly ask for the help again through this post.
once again, thank you
  • john
