hi
how can i create a single wall in dragonfly legacy for envimet spaces?
thanks
hi, I also have the same problem, the command “single wall” does not seem to be available in dragonfly legacy, is there a workaround to model single walls?
thank you
Hi @lemar,
You can only add horizontal single walls with Dragonfly Legacy.
If someone has a good idea about how to generate surfaces made by voxels I would be happy to improve the single wall component.
Antonello
