Hello all,
I have a question about sky dome.
Can I visualize a Tregenza sky dome with more than 145 patches?
Your help would be much appreciated.
Yuta
Hello all,
Yuta
Hi,@Yuta Sky dome used skymatrix for the calculation. You can set skydensity to 1 which used Reinhart Sky with 577 + 3 patches.
@minggangyin
Thank you for the reply. It was very helpful!
If I want to generate a higher resolution sky dome with 2305 or 5185 patches, I need to change python code?
Thank you in advance
Yuta
@Yuta The image you post is Radiance sky. You should refer to gendaymtx command.
https://www.radiance-online.org/learning/documentation/manual-pages/pdfs/gendaymtx.pdf
Just to add to what @minggangyin suggested, you can also do this with genskyvec if you are interested in visualizing a single instance rather than a time-series.
