Hi
I’m trying to do an “Annual daylight gridbased” analysis.
I keep getting an error from the Sky Matrix node. I’v tried several epw files, but all seem to fail.
Anyone who can help?
Hi @klausvm, The Dynamo plugin has been broken and I haven’t had a chance to take a look to how Dynamo has changed during the current releases. For what I can see from the error you need to explicitly provide other inputs to ensure the input type matches what is expected by the node.
I am having the same issue, did you ever get this resolved? Thank you!
