Sky subdivisions (MF) used in Honeybee Imageless Annual Glare
Dear all,
I wonder what is the MF used in imageless DGP in Honeybee and whether radiance parameters (including MF) could be customized for imageless DGP calculations. Many thanks!
Sichen
Hi @SichenLu,
The recipe uses MF:1. Technically you could change the parameters (including MF) of the recipe, but it is required that the parameter is exposed as an input to the recipe, which is not the case with MF.
If you really want to you can hack it by editing the file as shown below.
Hi Mikkel,
Great, thank you!
Sichen
