Trying to define skylights i see that the only method to define them is face.apertures_by_ratio_gridded
I wonder (and wish) if it is possible to use other methods, like those used in facades: face.apertures_by_ratio_rectangle
and face.apertures_by_ratio
Tried to apply the AperturesByGuide component but for the roof it seems to be taking triangle meshing.
At the end i want to get rectangle skylights, like those in the LBT examples (where BTW I see they are defined by input geometries).
In the case it is no possible I make a wish here to enable this option .
