when i try to use Skymatrix component i get error:
Runtime error (SyntaxErrorException): unexpected token ’
I’ve 1.3.0 version. Rhino 7.
Thanks!
Thanks!
What version of Radiance do you have installed?
Check The compatibility matrix also if needing links to download the correct version
Yes, I’m using the latest version of Radiance (now I’m reinstalling it again to 5.4a (947ea88a)). And if i use LB older versions with samples then skymatrix works.
huh… that’s odd: I’m afraid this is probably out of my kneejerk scope of “knows solution” then: @chris I tried
Perhaps it is related
Solved, i reinstal LBT and now all works.
Is this related to your problem?
I have tried to reinstall LBT and radiance, but there is still the same error.
