How would I set the EP Construction type for surfaces that are considered “Slab on Grade”? The “setEPZoneConstruction” component only has inputs for exposed floors
The material plugged into exposed floor doesn’t affect slab on grade surfaces. How can I assign a construction to those surfaces?
Thanks!
