I am confused about using SnappyHexMesh for meshing 9 buildings.I used the example file called 0.1_0_outdoor_airflow.I just changed the building geometry,other settings is default.
I am using Butterfly,with OpenfoamV1612+ in Windows 10 64bit.The blockmesh worked good.And the snappyhexmesh crashed in the process.My computer memory is not enough? Or some settings wrong?
Could you help me solve this question?
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: v1612+ |
| \ / A nd | Web: www.OpenFOAM.com |
| / M anipulation | |
Build : v1612+
Exec : snappyHexMesh
Date : Aug 27 2017
Time : 09:39:54
Host : "default"
PID : 13443
Case : /home/ofuser/workingDir/butterfly/outdoor_airflow
nProcs : 1
sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
Read mesh in = 2.14 s
Overall mesh bounding box : (-241.5472 -241.4418 0) (496.4376 536.2438 144.8633)
Relative tolerance : 1e-06
Absolute matching distance : 0.001081851
Reading refinement surfaces.
Read refinement surfaces in = 0.01 s
Reading refinement shells.
Refinement level 3 for all cells inside around_buildings_area.stl
Read refinement shells in = 0 s
Setting refinement level of surface to be consistent with shells.
For geometry outdoor_airflow.stl detected 0 uncached triangles out of 120
Checked shell refinement in = 0 s
Reading features.
Read features in = 0 s
Edge intersection testing:
Number of edges : 1684728
Number of edges to retest : 1684728
Number of intersected edges : 5583
Calculated surface intersections in = 1.68 s
Initial mesh : cells:554112 faces:1684728 points:576779
Cells per refinement level:
0 554112
Patch Type Region
outdoor_airflow:
6 wall buildings
Added patches in = 0.03 s
Number of edges to retest : 0
Selecting decompositionMethod none
Found point (127.4452 147.401 72.43167) in cell 402042 on processor 0
Marked for refinement due to surface intersection : 8820 cells.
Determined cells to refine in = 3.87 s
Selected for refinement : 8820 cells (out of 554112)
Number of edges : 1883850
Number of edges to retest : 250376
Number of intersected edges : 21198
Refined mesh in = 1.77 s
After refinement surface refinement iteration 0 : cells:615852 faces:1883850 points:652499
0 545292
1 70560
Marked for refinement due to surface intersection : 38502 cells.
Determined cells to refine in = 0.04 s
Selected for refinement : 40392 cells (out of 615852)
Number of edges : 2787132
Number of edges to retest : 1118049
Number of intersected edges : 85655
Refined mesh in = 3.17 s
After refinement surface refinement iteration 1 : cells:898596 faces:2787132 points:990317
0 543235
1 48681
2 306680
Marked for refinement due to surface intersection : 159213 cells.
Determined cells to refine in = 0.1 s
Selected for refinement : 168471 cells (out of 898596)
Number of edges : 6576117
Number of edges to retest : 4737635
Rhino Model and GH files is in t’he zip file.Please help me solve this question!~~
9_buildings CFD simulatiton.zip (460 KB)
