I’m trying to get the total solar Irradiance on the panel surface around peak afternoon time with a clear sky condition in Mumbai-India.
I’m using the “HB Point in Time Grid Based” recipe for the simulation.
As per my understanding, the solar Irradiance should be in the range of 900-1000 watts/m^2, but I’m getting a maximum of around 500 watts/m^2.
My question is does this component evaluate the Irradiance only for the visible Light?
If yes what can we do to get the total solar irradiance on a surface for a particular time in a day?
Ravi
The script looks ok, but we can’t see the settings for the CIE sky.
Hi @LittleBuddha ,
Here’s the
SolarIrradiance_0407.gh (103.5 KB)
file if you need it for reference
I dont have a PC available, so will not be able to check your file.
Please share a wider screenshot, and I will have a look.
Hi @LittleBuddha,
Here it is…,
Hi.
the file sent includes to much stuff, for me to want to try to find what is wrong. And you are using pufferfish, that I dont have installed.
I suggest that
- try removing the x unit vector from the sky model, it should not be necessary.
- if that doesnt help, try draving a simple flat surface in rhino, grid that, and run you calculation again.
- if that doesnt work, internalize the geometry and upload the file again and perhaps someone will look at it.
Sorry, but this is all I can deliver as of now.
Yours,
Little Buddha.
