Solar radiation analysis considering the reflection of the ground and surrounding buildings
I would like to analyze solar radiation considering the reflection of the ground and surrounding buildings using the exterior wall of the building as the analysis surface.
Is it possible to do the above analysis?
I thought it was necessary to analyze with honeybee to consider the reflection, but I could not analyze it well.
I would appreciate it if you could lend me your wisdom.
Thanks in advance.
