I am trying to get a pattern by using solar radiation result but dispatch did not work. What is problem with me? Thanks.
dispatch.3dm (342 KB)
dispatch.gh (76.2 KB)
maybe an,image or,exemple of what your are after will help people here to understand your problem.
Hi Ugur,
Attached a working version. Somehow your mesh explode component had a different number of faces comparing to the calculated mesh.
dispatch_A.gh (73.6 KB)
Thank you so much Abraham…
