I am using HoneyBee 1.4 and I need my model to use solar shading when it reaches X value of solar radiation on the facade (windows). I have seen that in previous versions of Honeybee there was a component for it, where a schedule could be programmed, as well as other options that are no longer available in version 1.4. Or maybe I can’t find them. Could someone help me with this?
Fig. 1. Honeybee 0.0.66 component.
Fig. 2. Honeybee 1.4 component.
consultaMixedMode.gh (260.4 KB)
Thank you very much in advance.
Hi @cerianipascual,
The schedule can be put in teh window construction shade component.
Hi @Erikbeeren thank you very much for your help.
I am trying to put some interior curtains on my windows but I am having problems. When I use this configuration Fig. 1, the Lover Shades component asks for depth. If I put the same as the shade material thickness, it gives me an error, as shown in Fig. 2.
The error is: 1. Solution exception:Expected ShadeConstruction. Got <class ‘honeybee_energy.construction.windowshade.WindowConstructionShade’>.
Fig. 1.
Fig. 2.
I think the problem is not the thickness, it’s something else. Do you have any possible solution? Maybe I should configure the curtains differently?
One other thing, only to clarify, I decided to use a setpoint temperature to control the curtains.
Thank you,
Pascual.
