It seems that the rotationAngle input of the SolarAdjustedTemperature component does not rotate the 9 points representing the mannequin. Obviously this is not evident when rotating in the sitting or standing position due to the symmetry of the points, however when the bodyPosture is set to Lying Down, the issue is clear: Changing the rotation value has no effect on the rotation the points.
In the attached image I have connected the same Body Position and Rotation inputs to the ComfortMannequin component which does rotate correctly in all positions. I would upload the file but as I am a new user I don’t have the privileges required to do this. Hopefully the image will suffice.
I have updated both Ladybug and Honeybee to the latest release and updated all components on the canvas.
Is it just me or is this a known issue?
Cheers,
Adam
