holle everyone,
I am trying to use honeybeeplus to run annual daylight simulation,but it failed to get the result of sDA and ASE.
the error shows:1. Solution exception:Failed to load the results form an empty file: C:\ladybug\parametricIlluminance\octopus\octopos0905\gridbased_annual\result/scene…default.ill
Double check inputs and outputs and make sure everything is run correctly.
