Hello. I receive this error when I change report frequency from hourly to annual in energy simulation. Where is the problem?
This is a bug in the last stable release of LBT (version 1.3). It only happens when the Annual
_report_frequency_
is requested. Using the Monthly
_report_frequency_
will make it go away. Alternatively, you can update to the latest development version of the plugin with the LB Versioner where this bug has been fixed.
Hi chris it seems the problem is still there? I am using LBv1.6.65
Hi @Julieee ,
If the version number on your component reads 1.6.0
or above, then this is something different than the original bug. If you upload a sample .gh file that recreates the issue, I can take a look.
