Hi everyone,
I hope you’re all doing well. I’m currently working with Ladybug and have encountered an issue. When I work on a file, everything runs smoothly, but as soon as I try to copy the file, I receive the following error:
“Solution exception: name ‘w’ is not defined.”
Has anyone else faced this problem? If so, could you share any insights or solutions? I would greatly appreciate any help!
Thank you!
