Hi, I would like to clarify if there is anything wrong with the inputs? I tried the same script with a different model and worked but it does not work with this 3D model.
Thank you!
Study Room Daylight Analysis.gh (610.4 KB)
Thank you!
@snoringpanda96 , just run the occupancyfile component and generate your schedule before you connecting it to Honeybee_Read Annual Results 1.
You will be able to see your results after this.
