Hi there,
Could anyone help me with this error?
Solution exception: ‘Room’ object has no attribute 'units’
The unit of Rhino is based on meter and I have no idea what I should to solve this error.
Thanks in advance.
Hi there,
Thanks in advance.
It seems like you are using a component that is meant to take a Model input but you are plugging in a Room instead. Add the Rooms to a Model and then try plugging the model into the component.
