Solve adjacencies component
I updated my Honeybee and Ladybug but somehow the solve adjacencies component is responding unusually. A simple example is provided below. Can someone help to find what is wrong here?
Zuhaib
Rhino
Solve_adjacencies.3dm
Grasshopper file:
Honeybee_solveadjacencies.gh
Hi Zuhaib,
Please internalise your brep then save file. and upload that again.
right-click on brep set the internalise data.
best,
Omid
Same idea, it seems to work fine when I assigned the same geometry from your Rhino file…
Zuhaib,
Edit:
It works for me. please find attached.
best,
Omid
Honeybee_solveadjacenciesOMD.gh (460 KB)
Thanks Omid,
There is some problem in the honeybee installation I suppose. Your file shows the same problem in my system. Thanks for help guys.
I tried rectifying this problem but even in my other grasshopper scripts, it shows the same error. I am unable to locate the source of the problem.Regards
Zuhaib
Zuhaib,
Have you checked these discussions?
1.this and 2.this one.
best,
Omid.
Hi Omid,
Thanks. I figured it out as my Rhino version was previously 32bit before updating LB+HB so the scripts were showing this problem with Solve_adjacencies component. The moment I ran the script with 64bit the error was gone.
Regards
Zuhaib
