Hi All
I am having a problem with solving adjacency during optimization. If I place two identical boxes above each others and then I start increasing the size of the lower box in the x and y direction, the ceiling surface still reads as a whole one indoor surface it does not understand that part of the ceiling became exposed to the outdoor. Hope you could help me with that.
thank you
Hi, @Amany.khalil
According to your descripition, I can not understand your problem. Please upload some screeshot or your rhino file or your grasshooper definition.
Do you intersect the geometries before creating the zones?
Thank you Mostapha. I used the Honey-Bee intersect masses component and the problem was solved. But the two words “No sun” and "Sun exposed " appears in the exposed surface when I increase the projected length. Attached are the two photos. I just want to ask if this means the program reads the exact exposed surface area or there is still a problem?
(upload://y1pF9IpHtPzIXc9sol83vGbAFSG.jpeg)
