Solve adjacent component
I encountered a hiccup with solve adjacent in LBT. I have a bunch of rooms pieced together as a building. If I assign room type to each room separately(even if they are all same room type), the solve adjacent component won’t work. If I assign room type to all rooms together, the solve adjacent works.
Based on scenario 2, I think my geometry is correct even if i can’t examine it with tolerance.(maybe I can via rhino setting.)
I tried to give each room a unique name but the issue still occurs.
Any thoughts?
SolveAdj.gh (523.0 KB)
Hi @gqiu,
This could be a way.
SolveAdj.gh (512.4 KB)
Erik,
Thanks for your solution. It makes sense and solved my issue!
