I’ve just recently installed Ladybug-tools on my mac along with openstudio as specified on the install guide as we are using these for energy calculations at Uni. It seems to think I have an old version of energy plus on my laptop as I cannot run anything due to it having a compatibility issue seen below. I have checked and I have the required version on energy plus installed, so I’m unsure how to get LBT to read the correct version of Energyplus(22.1.0). Any help would be appreciated.
No idea how to change file path routes to make it work. I ended up getting a fix by uninstalling all old versions of OS, but it wouldn’t work until I had installed OS in the default location (applications folder) and then ran the LBT installer gh file again.
A bit confusing cause on the installation guide LBT tells you to put the OS install location in the LBT folder. But I got it working, yay!
