Dear all,
I got the following error message when trying to update the LB+HB components used in the current GH file.
I’ve already updated the LB+HB installed on the computer.
Appreciate if you can kindly advise what’s the source of this error.
Thank you!
-Ji
… OK, let me reply myself:
Line 117 in the updateLadybug component is to check components inside cluster, and it is not able to access the one of the clusters which is password protected.
Removing the password of the cluster solves the problem.
Maybe we can add a “cluster password protection” check in the updateLadybug component…?
