[SOLVED] intersect mass and solve adjacency issue
I have three adjacent closed breps.
However, I’m unable to get the two interior walls as shown below:
The three breps are defintely overlapping over those two interior walls because if I bake the breps into Rhino and use solid union to join them, those two surfaces will be removed as shown below.
Image 2
I wonder what is causing this issue… and I have several other groups of breps having the same problem.
Appreciate your kind suggestion. (GH file attached)
Thanks.
unable to identify interior wall through intersect zone surfaces.gh (495.3 KB)
… seems I made a mistake for not using Meters as unit. The components are working correctly as expected.
