Some of the components of ladybug don't exist in the toolbar
hi every one
I recently have downloaded ladybug and installed it, but unfortunately, some of the components don’t exist in the ladybug toolbar, for example, I don’t have ladybug_epw or ladybug_outdoor comfort calculator, ladybug separate data and some other components, anyone knows what’s the problem with that?
btw I installed the latest version of ladybug
Hello @farzane.eskandarii, It appears that you’re missing an avatar! Please set it up in your profile! Thanks. :slight_smile:
Did you restart Rhino after the installation?
yes I did !
I really don’t know why it doesn’t work !!
Check the UserObjects folder and see if all the userobjects are copied. If yes close Rhino and Grasshopper. Re-run Rhino and then run Grasshopper.
yep, some of the user objects weren’t in the folder, I overwrite all of them
it works fine now, Thank you
Great! Please update your profile picture as suggested by admin. Thanks.
