Hi all
I am experiencing some unknown issue with honeybee. After I updated the whole script manually I ran into a message “1. Solution exception:honeybee_ExtraConstrProps”
In the report it says:
Current document units is in Meters
Conversion to Meters will be applied = 1.000
[1 of 8] Writing simulation parameters…
Can’t find ddy file next to the EPW.
Extreme values from the weather file design will be used instead.
[2 of 8] No context surfaces…
[3 of 8] Writing geometry…
[4 of 8] Writing Electric Load Center - Generator specifications …
[5 of 8] Writing materials and constructions…
Runtime error (KeyNotFoundException): honeybee_ExtraConstrProps
Traceback:
line 2152, in main, “<string>”
line 2364, in script
In order to solve it, I followed the topic below:
http://www.grasshopper3d.com/group/ladybug/forum/topic/show?id=2985…
In my case I only ran into further troubles with IDF file and some message about missing ControlProgram in Objects.
I am uploading the gh file for you to see. PLS help me, I ran out of ideas.
BC_test1.gh (700 KB)
