https://www.ladybug.tools/spider-2021/spider-viewer/
Now loads and display all HBJSON shade types (still some triangulation issues here and there)
Commented: //renderer.outputEncoding = THREE.sRGBEncoding; ~ changes the coloring a lot - not sure whether good or not
Add scene.traverse: updateVertexNormals & material.needsUpdate - improves shading and shadows
Add generate animated GIF ~ 512x512 experimental feature ~ Try it from the Exporters menu
Update exp-exporter.js menu
Update user interaction:
When single model open: mouse down updates entire scene
When multiple models open: mouse down over building moves the building. mouse down in space updates the scene
Fixes to drag and drop process
The animated GIF routine is adapted from Mr.doob’s example.
demo: Animated GIF generator
code: GitHub - mrdoob/omggif-example: Animated GIF generator example. · GitHub
The GIF are created in less than minute. So it’s fThe limiting feature is that GIF only supports 256 colors
The idea behind this feature is to help you get your designs into Instagram and even TikTok. If anybody is interested in animated GIFs I will continue, otherwise I may move on to MP4 videos. In any case, still image capture will happen soon.
Discourse accepts GIF - but only up to 1024K in size. I just made this example at 256x256 resolution. You can see the effect of the limited colors in the background,
