Split Building Mass 2 Floors component not working
Split2Floor Problems.gh (459.6 KB)
Hello all!
I am running the same script in 3 computers, daylighting simulation with HB zones. The computer number 1 has HB and LB for a while now so its not the new version, and it runs perfectly. The computer 2 has the latest HB and LB version and runs perfectly. The computer number 3 however, I just installed LB and HB today, does not run in any way, and the problem seems to be the SplitBuildingMass2Floors component.
Firstly I installed the latest version, then I uninstalled everything and installed an older one, and it isnt working.
The error I get can be seen in:
I also tried making a scrip from scratch to see if the component would work and still nothing. This file is attached here if someone wants to take a look.
Some help would be very much appreciated! Thanks!
Try to change Rhino units. For example to meters.
Already did :confused: didnt work. But thanks for the suggestion
Hello there, any solution found yet?
In my case I have the same issue, but only in Rhino 7. When I run my script in my Rhino 6 it works without problems.
It has been an issue with R7. It was solved. You need to update your component to the latest version from github.
Right, thanks Abraham, problem solved.
For others, here you can find the updated component:
honeybee-legacy/Honeybee_SplitBuildingMass2Floors.ghuser at 1494fe0f1be514675511b7c19a625264aa31393b · ladybug-tools/honeybee-legacy · GitHub
