Split system HVAC or heatpump (cooling only)
Hi everyone,
Does everyone have any idea how to model Split HVAC system (heat pump but cooling only)in honeybee? Looks like there is no heat pump or split system in the ‘Honeybee_HVACSystemList’.
Or, is there any alternative to model this system through modification of one particular HVAC system (e.g. ideal load system) by changing the input in ‘Honeybee_HVACAirDetails’
Please give me any idea or guidance about this
Regards,
Wendy
@sunarywend, you can use Packaged Terminal Heat Pump (PTHP) with heating capacity 0, or build your own air loop with DX cooling coil.
Allright. I see, it makes sense
Thanks for your suggestion @MingboPeng
