I have the issue, that the sql file from OS results as _data for the HB_color rooms is not readable. This kind of solution was at the Hydra-tutorials with an early version. What kind of data is required?
Thank you!
Thank you!
For face-level results, you have to use the HB Color Faces component. Not the HB Color Rooms component.
I know it’s a little confusing because we switched the icons of these two components between Legacy and LBT. The icon with colored Faces just made a lot more sense for the “HB Color Faces” component.
