SQL Empty Results
Hi everyone,
since I installed LBT 1.5 i have problem with Openstudio results. It doesn’t give to me any sql results, like air and operative temperature. I tried with an old thermal analysis file which worked with LBT 1.4, but I have the same result: “Empty Generic Data parameter”. Maybe is there a new method to calculate the Openstudio analysis?
A simple example file:
Villetta S. Erasmo - TEST.3dm (905.5 KB)
Villetta S.Erasmo.gh (259.7 KB)
You probably need to ask for the proper outputs. Otherwise you don’t get what you are asking fo. Like so:
