Devang, anton and i were working on this together (he submitted this for me). the issue is that when the base plane is a mesh or surface plane the analysis does not work. as soon as i feed a closed brep into the analysis (same exact location and grid size) the analysis works.
I continue to run into this. I am also noticing that this analysis struggles with multiple breps.
I might add that in this file i can get the example geometry to run just fine as well
the 10 meter grid came from a much larger area being analyzed… the surface still returns no result (0) but when the same surface is thickened to a brep it returns 9 full hours of sun
i suspect there might be something to do with too far from the origin. will report back soon with my findings.
