Hi! Does anyone have an idea why I get this result when baking with the ReColorMesh component? The meshes look fine when previewing in Grasshopper, but I only get these lines when baking them (using the bakeIt option) – both the meshes and the legend look like this. It has always worked fine before, so it seems to be something specific to this simulation – but I cannot find out what…
Hi Daniel,
Can you please share the grasshopper file?
Sure!
recolormesh_bake.gh (373 KB)
Hi Daniel,
Checked baking at my end. Works fine. I used the meters template in Rhino wth 0.0 tolerance.
Works fine for me as well!
Oh, I just tested in a blank document, and it worked for me too. So it must be some render setting/problem in the Rhino document. I tried different settings, but no luck.
Anyway, now I have a workaround. Thanks!
…and if anyone knows what might cause Rhino to render meshes/hatches like this, let me know
