Hi guys
I’m working on a script for early-stage LCA calculations.
The goal is to be able to take simple volume study model > use Ladybug Tools to create rooms (thereby auto-defining if a surface is a wall or a roof, etc.) > save the sub-divided geometry on a separat layer in rhino > export data to the Real-Time LCA webapp using Speckle and make the CO2 calculations there.
On this topic, I figured out how to simplify the geometry, when the surfaces weren’t coplanar, like the example below: Simplify polysurfaces - Rhino - McNeel Forum
So far so good Now my next step is to subdivide basement from the rest of the building, as basement construction usually are a lot different than the rest of the building.
The HB Visualize by BC
component can show me, what part of the geometry has the Ground boundary condition, but as the output is mesh instead hb_objs, I can’t add the HB Visualize by Type
after HB Visualize by BC
Is there another way to do this?
