I was ceating sun path in dynamo-ladybug. I did not face error, the watch shows ( All good,Vvizzz) . However, unfortnately it dose not show the sun path graphic.
I was wondering if you could assist me in this case if possible please.
See first question on this page:
fortunately the problem is solved. I changed the revit unit from mm to metric and it worked.
