I try to use sun shades calculator, and it always show “solution exception: exception Point3d, got NoneType” or “No enough intersection points to calculate the shading surface.”
I downloaded the example file through Hydra:
SunShadesCalculator (hydrashare.github.io)
I tried to use the original components in the file. Also, I replaced all the components with those from ver1.7.0 (except for the Sun Shades Calculator itself). Neither of them worked.
Meanwhile, I tried Shading Designer file through Hydra, and it can run smoothly. I think there were no missing files or errors during my installation of Ladybug.
[image]
Shading_Designer (hydrashare.github.io)
I install ladybug tools through pollination, the ladybug tools version is ver1.7.0, including LB-Legacy (ver0.0.69)
Is there any method to solve the problem of sun shades calculator, or there are
any new alternative to use?
Thank you!
