Hi
I have a problem with a Ladybug_Sunlight Hours Analysis Tool in Grasshopper, that its analysis results on my case have a very smaller range than what it should.
I attached the analysis results of two different cases with different forms and the same conditions. In the Jpeg File, the upper one is the case with the problem and the lower one is a normal case in the same condition.
I’ve also put the rhino model and the ladybug algorithm in the attached link.
NEED HELP
Download Files
