Sunlight hours - One sensor point per window
Hi guys
I want to use the center point of each window in my model to calculate the sunlight hours on each window. I want the result to look like this, with one colour and value for each window.
I can easily find the center point a surface, but don’t know how to convert that into a mesh. And if I don’t have a mesh, I can’t use LB Spatial Heatmap to colour the surfaces.
This could be a nice feature to add to the HB Sensor Grid from Apertures component.
Hi @MarkLabrosse
If you input a grid size number much bigger than the apertures size you can get single points with
HB Sensor Grid from Apertures.
hopefully that’s helpful.
Thanks @TrevorFedyna, that’s exactly what I was looking for!
Awesome! happy to help
