Hi all!
I would like to ask you some question regarding the SunPath simulation through LadyBug.
Is it possible to run this kind of simulation referring only to one particular facade?
Because i have tryed to do that using the LadyBug_SunPath component and giving the center of my facade as the centerPt input, but i still receive results when the sun is, let´s say, on the back of the facade…It seems as the component doesn´t consider the normal of the facade.
I attached the image to show you better what i mean.
Is it possible to have the result of the sunpath (Azimut, Altitudes…) just referring to one precise facade?
Thanks a lot in advance
Claudia
