Sunpath Shading crash
Dear All
Hello! I want to get solar power.
To include the influence of shadows on the sun,
I want to use the Sunpath Shading component, but there is a conflict when I run it, so the rhino is terminated.
Can I know the solution? Thank you.
Probably @djordje can give some light here.
Hi @JaeWon.Kim ,
Is it possible to attach your .gh and .3dm files?
@djordje
Pressing Boolean turns off the rhino and creates CrashDump files on the desktop.
Thank you for your answer.
Sunpath Shading test.gh (421.9 KB)
Thank you.
I ran your definition on my Rhino 6 SR21, Windows 10, and it works without issues:
@djordje
Thank you for your kind reply. I am using the rhino 7 and it seems to be my computer problem…
:sob:
I don’t own Rhino 7, so I can’t test it at the moment. What is your PC configuration?
I’m running R7 and it works just fine:
@djordje @AbrahamYezioro
Window 10, rhino 7 , Ram 16GB , graphic card= Intel IRIS PLUS
I don’t know why there’s a conflict. Maybe it’s my computer program, but I can’t figure out the cause.
And there is no problem with other components.
@djordje
Hello! I finally solved the error I posted last time. It was resolved after the liner update.
Can I ask you a question?
We get solar power generation based on PVwatts, but can’t we put a series or parallel effect here?
Or am I not finding it?
Can you give me an answer?
Thank you.
