Surface feature extract
is there a way to call surfaceFeatureExtract to better define the edges while generating the mesh with snappyHexMesh in butterfly?
In butterfly, before running snappyHexMesh, we run surfaceFeatureExtract on projectname.stl with the setting “includedAngle 150;”. If you want to change the settings of the surfaceFeatureExtract, double-click Butterfly_snappyHexMesh and rewrite the following part of the Python script. _case.project_name is the name of the STL.
        sfe = SurfaceFeatureExtractDict.from_stl_file(_case.project_name,
                                                      includedAngle=150)
