Dear community,
I am running an outdoor airflow simulation with butterfly, and the results I am getting for the surface pressures seem to be incorrect. Any help is appreciated!
Below I will post 2 cases and elaborate on them. For clarification, I am visualizing the pressures as vectors to make it easier to see if they are positive or negative (positive will point inwards, and negative will point outwards). In both cases, the wind speed is 30 m/s and orthogonal to the front side of the butterfly geometry.
Case 1
The simulation is performed on a cube with 10 m sides. Here are the results:
Here, the pressures on the windward side seem to be okay, but on the sides and the leeward end I am getting positive pressures. These should be negative, right?
Here are more pictures of the colored mesh faces:
Front
Back
Pressure Values
This is the solution log: simpleFoam.log (421.8 KB)
Case 2
Here, the simulation is run with the same parameters, but on an extruded surface with thickness of 5 m.
Here the vectors point as they should (positive on windward side, and negative on all other sides)
Further pictures:
Front
Back
Pressure Values
Does anyone have an idea why this is happening? I can provide more files if they would help in resolving the issue.
Thanks in advance!
