Seeking the generous advice from LB community,
I have built a setup to measure the outdoor thermal comfort in a courtyard house. The geometry parameters (courtyard dimensions, windows proportions) will eventually be fed into an optimization component to maximize both indoor and outdoor thermal comfort.
I am thinking of dividing the workflow into two parts, and this thread is addressing few issues with regard the outdoor. The setup includes:
- The geometry pipeline
- The Honeybee model (construction setup) and the (honeybee model with apertures assigned to specific face with ratios) and the ( energy calculation).
- The Eddy 3D (not connected yet but upon computation result will be used for air/wind speed/ velocity in the UTCI component).
- The UTCI component, where I am facing a couple of issues:
The surface temperature: should I be using the radiance component that calculates the temperatures for the courtyard faces (walls+ floor) or should the temperatures come from the OSM calculation?
In case the face/ surface temperatures are to come from the OSM, I am trying to list the courtyard faces only from the SQL results, but not sure why the number of faces is different in the results from the HB model? is that a valid approach to feed only the courtyard surface temperatures and should they be averaged in this case (annually per surface?)
Thank you for this great community,
F_1.gh (274.0 KB)
Final_2.3dm (55.9 KB)
